Semi black bar in bottom of screnn
For a longer period of time, a semi black bar has appeared in the bottom of my screen.
It is most visible on light backgrounds.
In the attached foto you will be able to spot it on the left side of the person below the tables.
Any ideas as to get that removed?
Thanks in advance
Forgot to tell you, the TV is the KD-55AG8 model
LightFoot
Specialist
Hi @JensAJensen   It looks like image retention. All TV manufacturers see this as a misuse and a user fault. You could try a panel refresh.
https://www.sony.co.uk/electronics/support/televisions-projectors-oled-tvs-android-/kd-55ag8/article...
