Sky Q remote not switch off tv
standishman65
KD-55XH 9505 cannot switch off with Sky Q remote,set up with Bravia Sync,exact model number selected on Sky Q box ,done power downs.Any help please.
12 REPLIES 12
LightFoot
Specialist
Hi @standishman65
Sky Q does not turn off any TV using HDMI Control (Bravia Sync/CEC/etc.). That function is not included with Sky Q.
Assuming that the remote has been correctly paired with your TV then hold down the Sky Q remote power button for 2-3 seconds and that should put the TV into standby. So it requires two presses on the Sky Q remote power button. Short one for Sky Q and longer one for the TV..
Piscie
Community Team
Hey @standishman65, this issue is related to the Sky Q box. Have you tested the Bravia Sync features with the Sony remote? Does it turn On/Off both devices? As this feature is mainly allowing you to use your TV's remote to control other Bravia Sync compatible devices.
Matt84K
Thanks for this.
I have just upgraded our Bravia and was having issues with the restart problem.
Bang on 3 seconds and off it goes.
Happy wife Happy life!!
Elodin
Moderator
Hi @Matt84K, you should probably check this article here: Link. I hope this helps
Matt84K
Thanks Elodin
Still getting my head around the myriad of settings and getting my soundbar to play nice.....
Matt84K
Double post!
SkyNet404
Specialist
What's wrong with the soundbar itself? Is it a Sony SB? Or not?
Matt84K
Hi SkyNet
Its a Sony soundbar. Just a few issues regards menus etc. Think I'm there now. It was a lag in lip sync which I eventually found. Typical bloke in that connect it all up and then read a manual when something isn't right. Or that's what the wife says but what do they know? LOL
royabrown2
Hero
@Matt84K
Wives know:-
Switch it off and switch it on again.
Reboot it.
Reset it.
Go in the other room and watch the non-Sony TV there 😛
