Partagez votre expérience!
Hi, relatively new Bravia with Android updated to 3.533 has slow EPG, when activated sound goes off for few seconds and even the guide comes up in a second, it goes black for couple of seconds. Then viewing guide no problem, but when exiting screen goes black and sound off for 3-5 seconds.
Any setting causing this or just bad app?
Résolu ! Accéder à la solution.
Hi there
This is a known problem and is resolved under the Marshmallow (Android 6.0) update. Sony will/should be re-starting rolling out this update soon.
https://community.sony.co.uk/t5/android-tv/android-tv-bugs-and-issues/m-p/2040066#M48
Hi there
Sounds good. Thanks for the information!
