Sony A1 55inch oled Dolby vision update that ruined my television
Tortoiseken
Tortoiseken
Dear Hana with regards to my software I have the latest download reset the whole television done everything and my TV will not work with Dolby Vision the picture is really dark with Apple TV my DVD player and other sources Disney+ etc Looks like I’m one of the customers who’s been dumped by Sony lesson learnt
14 REPLIES 14
HannahEd01
Community Team
@Tortoiseken, could you elaborate more on the issue?
Tortoiseken
Sony A1 oled tv 55inch when I playback a DVD via my Sony X 800 DVD player the picture goes dark unwatchable when I play streaming films on my Apple TV via Dolby Vision my picture goes dark anything to do with Dolby Vision source creates this problem I’ve had it now for some time
Tortoiseken
It seems a number of paper I’ve got this problem and it’s a software glitch and is actually ruin my viewing £2500 what a waste of money Sony very disappointed
HannahEd01
Community Team
@Tortoiseken, I'm so sorry for you. What is the current software version of your TV? You can get it if you press Help on the remote.
Tortoiseken
Tortoiseken
Dear hana my tv is Sony A1 oled 55inch
daveyh64
Are the DVD and the Apple TV devices connected directly to your Sony TV.
If connected by HDMI cable directly to the TV have these HDMI inputs been set up as Enhanced.
Press Home on the remote control. (the path to this setting maybe different from the one described below as
not all Sony TVs have the same menus.)
Go to System> System Settings> Set Up> Av Set Up> HDMI Signal Set Up, select Enhanced for each HDMI input.
Have you adjusted the picture settings for each HDMI connected device.
It may be that you need to adjust the picture settings for each device differently from the picture settings
you use for watching digital terrestrial TV.
Each input device can have different picture settings from the other.
If the DVD is connected to HDMI 2 for example have you set up the picture setting to suit,
and the same would go for the Apple TV.
The TV remembers the individual picture settings for each device.
Switching between inputs will make the TV switch to the picture settings selected for that input.
Have you checked that any settings on the two devices themselves are set correctly for outputting to the TV.
SkyNet404
Specialist
Hey there,
I would highly suggest trying what @daveyh64 advised with, especially changing the HDMI signal format.
Hope it helps.
Tortoiseken
Sony has sent me a list of things to do what speed is my Internet and a whole list of things which is ridiculous seems to me like certainly are coming up with a smokescreen Sony A1 with Dolby vision is in watchable can you please send a engineer to fix it I will let everbody know how long it takes.
