This subject has probably been covered before, but I would appreciate some help if possible.
Does anyone know if there is a fix for the green hue appearance that appears over the screen when played with anything that has been produced with Dolby Vision on the A8H.
I get this green washed out effect from any source including Netflix/Disney.
Thanks,Michael.
Have you already done what solved the issue on this thread ?
Thanks for helping me with this very annoying problem, although I don’t see that anyone should really need to perform a factory reset for a problem like this. Surely Sony should provide an update to remedy this??
It's up to you. You can wait for a fix (even if Sony suggests to do a reset the TV before or after the upgrade) or try to do something to solve it.
