SONY A90J 65INCH - DEAD PIXEL
profile.country.IE.title
JayByrne
I have just received 65inch A90J TV and while checking the panel I have noticed a dead pixel,
Any hits or tips on how to rectify this issue, the tv is being used for 3 days now for extended periods and it is still off/dead.
I have read pixel refresh can help however also heard pixel refresh can cause other issues,
TV is within return period so just wondering what do ye suggest I do?
Any sony staff able to comment?
10 REPLIES 10
Joe_Dohn
Specialist
I would honestly try a software update in case it was caused by a bug/glitch, or just have it exchanged from the store.
EUSupport_EN
Can you provide us with a picture of the screen?
JayByrne
There are no software updates available.
JayByrne
Photo attached. Not sure whether to run pixel refresh or try exchange. Thing is the rest of the panel is very clean.
JayByrne
JayByrne
EUSupport_EN
Unfortunately, we're unable to see an issue with these pictures. This would be considered within factory specifications.
JayByrne
Thanks for your response,
For what is being called a Master Series and costing so much a premium over others I expect a perfect panel.
I am in contact with retailer for replacement and well within return policy should we not reach a satisfactory solution.
Joe_Dohn
Specialist
Hopefully, your next post is some good news!
