- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony AF9 vertical line
Has anybody experienced a vertical black line on the oled screen? I have also noticed a block of vertical shadow. It’s only 8 months old. Black line and shadow appeared after panel refresh and android update. Tried restarting and on/off. Didn’t help.
any troubleshooting steps to follow? I will ring John Lewis as well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Narendhar and welcome to the Community
You could try resetting your TV but as it sounds like a hardware problem then I'm afraid
there's nothing you can do to fix this and the TV will most likely need a repair / exchange.
See what John Lewis says, although contacting Sony Support would be a good idea too
Contact details Here
Keep us posted
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you. Screen is getting replaced.
Reset didn’t work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
I have a 12 month old AF9 and think the same issue here.
On the right side of the panel there is a thick block which is darker, on the left there is a brighter block. Nothing solved this until now. Hope the best with the service.
How long was the panel replacement?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
TV was replaced. I doubt display panel can be replaced.
Sony service was good! it was carried out by an authorised service provider.
Contract support if you haven’t already!
