After recent upgrade, I am unable to set up the language used for voice search, eg on youtube , it is now english only
There used to be a setting in home -- settings -- preference -- voice control (something like that) where you can set the default language and it is no longer available after upgrade.
the voice search function seems to be overtaken by google (on the buttom of the screen).
Very appreciate if anyone can point the direction.
There are indeed reports that the SPEECH preferences is not more available on the latest FW.
I am facing the same problem, Voice recognization is not working perfectly. Earlier used to change the channel from that now its showing some different results.
