Sony Bravia KD60XF8305BU
mandy30
why is there a lan cable when this tv has built in wifi please
LightFoot
Specialist
Hi @mandy30
According the the specifications “what’s in the box” there is no lan cable supplied. However it doesn’t matter as you can use WiFi or Ethernet, your choice.
mandy30
thank you so much for your help
