Sony Bravia KDL60W855 smart remote compatibility???
QinetiQ
Hi all,
I have a Sony Bravia KDL60W855 and I was wondering if any of the Sony smart remotes are compatible with this TV? It didn't come with one when I bought it but I read somewhere some Sony TV are smart-remote-ready and if purchased seperately, it will work. Any input will be highly appreciated.
Regards,
Stan
rooobb
Assuming you are talking about a W855C (but it should be a 65"...) the touchpad remote code is RMF-TX100E.
Keep in mind that you have the same features using the TV&Video sideview app on your smartphone without buying anything.....
QinetiQ
How about the touch gesture pad?
rooobb
What do you mean by touch gesture pad? you have different option as a remote controller via sideview (standard remote, touchpad, mouse pointer) that combine the standard remote and touchpad remote available for most Sony TVs
