Sony Bravia TV No Internet Access since V8.0.0 V6.6520 kernel: 3.10.79 Update
ancaise
KD-55XF9005 V8.0.0 V66520 kernel: 3.10.79
Since V6.6520  ( PKG6.6520.0252EUA )  software update we cannot connect TV to the internet. It connects to the LAN but without internet access.
WIRED was working perfectly and allowed software upgrade!
All devices in the rest of the house are functioning correctly
- network status, everything looks good and picking up DHCP correctly
connection methind: wired
cable connection: ok
Ip address setting: Auto
ip address: 192.168.8..205
subnet mask 255.255.255.0
default gateway: 192.168.8.123
primary dns: 81.139.57.100
secondry dns: 81.139.56.100
MAC: 70:26:05:B6:E2:AB
Proxy server: Not used
SAME FOR WIFI DHCP AS WELL
Connection Results
cable connection: OK
Local access: OK
Internet access: Failed
- i Can ping tv from laptop, so connected
- there are no sat or cable connections just HDMI from SKY and CAT5 from LAN
- tried a different cat5 cable
- different LAN port
- tried SKY box and Laptop in LAN port, both work
- checked date and time on TV and router
- recycled power via taking plug out of TV and router in between each stage / change
- tried DHCP & Fixed IP
- tried different router (current is Draytex) but tried BT Home Hub
-EDIT 01/08/19 - tried to connect to iphone hot spot - connects then just reboots and will loop until you quickly go in and turn off wifi or stop hotspot!!!
- EDIT 05/08/19 - tried setting primary DNS to the same as the router / gateway - local access then failed as well as internet
- data and storage factory reset
- tried firmware on USB but said its all up to date
- batteries out of remote and pressed button for 10 seconds
- stopped the SAMBA service
- EDIT 01/08/19 - As per Robs suggestion we had already tried fixed ip with google servers
ROUTER LOG, so its trying to connect
Private IP :Port #Pseudo Port Peer IP :Port Interface
192.168.8.205 55835 49307 10.10.10.10 443 WAN1
192.168.8.205 56402 49874 10.10.10.10 123 WAN1
192.168.8.205 60136 53608 216.58.206.100 80 WAN1 GOOGLE
192.168.8.205 52030 45502 172.217.169.67 80 WAN1 GOOGLE
Andy
14 REPLIES 14
rooobb
Try changing the DNS to a public one (like 8.8.8.8 or 8.8.8.4)
ancaise
Hi Rob,
The details I posted were DHCP, how it has always work.
When we tried fixed IP, we  used the two google DNS server IPs as suggested 😞
thanks
A
rooobb
I assume you tried but it is not working in any case even if you kudoed me....
ancaise
kudos was reading and replying :slight_smile:
even tried setting google dns as default in the router with no success.
tried connecting to iphone hotspot which nearly worked but once connected, just rebooted itself on every connection until i turned it off.
looks like a long and lengthy support call.. doh!,,
rooobb
Yes I think your only option is to talk with the support
ancaise
As of today I have an open ticket!
case:18870175
Dear Mr xxxxx,
Thank you for contacting Sony support.
We appreciate all the detailed information that you have provided us with.
We are currently investigating your case further, we will update you in due course.
Should you have any further questions, please feel free to reply to this email.
Thank you for your enquiry.
Yours Sincerely,
Sherif
SONY SUPPORT TEAM
ancaise
John Lewis who provide extended cover have been told by Sony it is a known issue and a fix is being worked on.
sewellpaul77
   Did you get a response and a solution to this issue please? I've had this issue on my XF9005 since the Oreo update where wifi keeps dropping and I'm looking for a solution.
P
ancaise
hi, apologies, thought Id posted my resolution to all the posts id replied to.
If you have other routers / extenders on the same network, it is worth unplugging / powering / disconnecting them all for a test.
Does your TV work when hard wired direct to the router?
A
The issue is now resolved.
There was another router on the home network, which been there for 2 years! with DHCP turned off but used to extend the wireless to a downstairs room. We were using a wired connection and both routers were connected to the same network switches.
The TV was definitely connecting to the main router as we could see it in the logs. It then briefly got an internet then disconnected.
After the software update, something must have changed that is now checking around the network and found the other router as it was delivering the same gateway address.
As we can recreate, happy to run any traces / logs / SDK traces for Sony if required.
This is resolved for us now, thank you for your time.
Regards
Andy
