Sony KD-49XE9005 Blank Screen
HI All,
Having a problem with my TV after disconnecting a Sonos Beam whcih was connected via the ARC HDMI. It could be coincidental but after disconnecting the Beam my TV won't switch on.
The TV is still on the wall currently and has power. The best I’ve got so far is a forced resetting by holding the power and volume down buttons on the TV whilst unplugging, waiting a minute and plugging he TV back in which gets the power light to go solid green, then the screen is meant to come on twice prior to resetting from what I have read but the screen doesn’t come on and I have tried just pressing the power button as well.
Anybody have any further ideas to try?
Thanks.
Peter_S.
Genius
Sounds like a technical defect (maybe the backlight).
I would recommend to contact an authorized repair centre.
Peter
