Sony KD 55A1
Fraz57
Sony KD 55A1
Downloaded latest software and now picture darkens after about 20 seconds. Its dull and horrible. Totally ruining my enjoyment of the World Cup. Tried all different options including light sensor on/off, no difference, really poor!
13 REPLIES 13
Almou_10
Specialist
Hi Fraz57,
I think a factory reset might help on this one. You can reset the TV from Home - Settings - Storage and Reset - Factory settings. If it didn't help, could you reply with a short video showing this issue?
Cheers,
Almou_10
Fraz57
Hi Almou
Tried a factory re set and no change.
A video wont help as my camera makes the picture a lot brighter than it is.
When I go into the menu,. the picture brightens up but it only stays sharp and bright for about 20 seconds then the brightness decreases and the picture looks dull, full of contrast and lacks sharpness. It then stays that way.
Either there is a fault with the light sensor or there is a software issue but someting will have to be done as the picture is shocking.
Fraz57
Hello again Almou
Just to give you an update, the picture is now actually flickering as well. Definitely looks like a fault.
Scramz
I have the same issue with dimming.
Watching the BBC Iplayer HDR Stream the screen dims and becomes almost unwatchable. This is on my A1 65 inch.
I never had this issue before until the DV firmware update.
Sony needs to allow us to roll back firmware until they fix this mess.
profile.country.AT.title
Kuschelmonschter
Hero
Check out this thread.
stormyuk
@Fraz57 The England game last night had a technical fault, from the FIFA broadcast, the commentators even mentioned it on BBC One in the second half as my TV kept going brighter and dimmer and its an XE90 which isn't supposed to have that issue. So many two issues here.
Almou_10
Specialist
Hi Fraz57,
Does this happen with all inputs ( including digital TV and streaming apps like YouTube)? If so, you can send me a PM with your contact details (name and phone number) and I can send to Sony to contact you.
Cheers,
Almou_10
Scramz
The broadcast last night had flicking issues, however, the TV is dimming. Same it happening right now on the Col and JPN match.
Scramz
On my A1 65, the dimming of the screen during football on BBC HDR stream makes the viewing unwatchable. It starts as it should then over the course of a minute or two it just gets darker and darker. This was never an issue before the DV update. Its as if the TV ABL is too aggressive.
