Sony KD-55AF8 needs tuning every day
vancouver2007
My KD-55AF8 has to be retuned almost daily, is there any reason this  keeps happening.
Joe_Dohn
Specialist
This is a basic thing to try and you may have already tried it, but it's worth mentioning; Have you tried disconnecting everything from the back of the TV (including the aerial/satellite cable of course) and unplugging the TV from the wall to depower the set for a few minutes then try turning it on again?
vancouver2007
Thanks for your reply, I tried your suggestions but still having to retune most days. I looked at the digital tuning settings and found a setting that scans the TV channels to make sure they locked in I assume. I have turned off  the setting, so far so good.
Win_88
Specialist
@vancouver2007
Sounds great. If the issue happens again, you can try tuning the channels with no antenna connected to clear the TV and the retune normally with the antenna again. I found that to fix most reception issues.
Win_88
