Sony KD-55X8005C Tips, Issues and Bugs Thread.
Opus3164
Have a problem with my Sony tv above, when I switch off the tv, and next day I will put it on, the TV4 doesn’t find the internet connection, but if I remove the electrical socket, and put it again, the tv find the internet.
What shall I do to let the tv find the internet all the time ???!! Thanks
Pascale_F
Moderator
Hi Opus3164,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Vanilla_
Hi Opus3164,
This could be a software glitch. Have you tried to check if the softwrae version of the TV is up to date: https://www.sony.co.uk/electronics/support/lcd-tvs-android-x80xxc_x81xxc-series/kd-55x8005c/download...?
If yes, then I'd suggest that you reset it to the default settings and check if the same problem remains.
Vanilla_
