Sony KD55XE9005 Internet connection drop-outs
profile.country.IE.title
Nsider
Hi ,I bought this TV a year ago and all has been fine until the last 5 weeks or so . The TV always connected to internet automatically now however it will not connect to the internet automatically anymore, if I go to settings and turn off date and time using network and then turn back on it will connect to internet however when TV is turned off and unplugged I have to go through the process again .I have all the latest firmware up dates version 7 any ideas
Hi there,
Have you tried a factory reset?
Best wishes,
M
Nsider
Hi Michael no I didn't try a factory reset because I have apps which I downloaded and would have to reinstall also picture settings as well as freesat channels which I had saved in favorites will all have to be saved again I was hoping there might be an easy fix but looking like I may have to do factory reset . Thanks
