SONY KDL - 50W756C Screen Faulty
lswbk1992
I was wondering if anybody had any advice. I have a 2 year old SONY KDL - 50W756C bought from Curry's. Initially the screen out of the blue had a problem in the bottom right hand corner, became very hot and looked like this:bottom rightbottom right
Now the screen has totally stopped working. I have been told that this is the screen and is not repairable by local TV repair people.
This item has a 12 month warranty from Curry's however I think it is unacceptable that a TV should last less than 3 years!
Does anybody have any advice?
Liam S
EdwinaU
Moderator
Hi there,
Welcome to the community.
You could try our repair and warranty service here for advice about your TV screen.
Best wishes,
Ed
