Hi All,
I've onging issues with a 65 XH90, details are follows...
Any ideas?
I'm on with JL Director Relations (due to a complaint early on when I was getting nowhere with the first line support), and to be honest he's being really supportive - however I suspect this is leading to another call with Sony Tech Support and Hard Reset (and all the follow-up settings activity) with a 'clean bill of health' following that.
Have I got a dodgy set which needs replacing, or is this the norm with this set?
Ideally I'd like to get this sorted before the ARC arrives, so any help/advice would be much appreciated.
Thanks in advance.
Regards
John
Hi John,
There should be a firmware update soon that fixes these issues.
Peter
Hi Peter,
Thanks for the quick response, however any idea when the firmware will be available?
Already been advised once to await an update (the last one on 21/01/21) but this never resolved the issue, and reluctant to wait much longer for a fix as don't want to get to the point I can't return to JL for a refund.
Thanks again.
John
