SonyTVRemote (AndroidTV) for Windows
profile.country.UA.title
svansvan
Hi, if intresting - I wrote a program - Sony TV Remote Control for Windows (FREE):
1) TV info, applications, programs, remote - from LAN
2) Tested: Sony TV (Android) 2015
1) when you first start you need to configure the TV.
2) The first run takes some time (network is scanned, downloaded application icons)
First test vesion.
(!!! Temporary, important: in file path: must not be spaces and cirilyc symbols)
direct download: https://yadi.sk/d/Sq4YtnyAqqoHJ
forum: http://4pda.ru/forum/index.php?showtopic=738311&st=0#entry48683078
(first version, for testing)
KD-55x9305c + SPS4 1208b
Hi there
Interesting indeed, well done.
Im curious to what your background is and what programming languages you are familiar with?
svansvan
Hi :slight_smile:
Programmer with experience of 15 years.
Now language c # vb .net, desktop, web.
a general written probably in the whole and at all :slight_smile:
I bought a TV, here and decided to just have fun. I have it just a hobby. and I do not like paid. so always give out the sources as desired.
I am doing this for a long time, if you drive in google search
"Svansvan" lngeditor bleeditor menueditor sdbeditor
then everything will become clear :slight_smile:
in general this is a very crude version ... there is so much to finish. control mouse, the current channel, text input, task scheduler, not all made the remote buttons, etc. ... it is just so that people try, know what it is, everything is quite simple, and it's all can do as the web-site. in general, it is not tv sideview, but we can do even more :slight_smile:
for Hotels for example, to collect statistics: what channels and how long it looks when switched on when switched off, etc. :)))
sorry for my english, I'm from Ukraine :slight_smile:
Awesome! Exactly what I have been looking for. Add an update option and a dark mode, and it will be perfect.
Thank you so much for sharing!
