Until channels ITV3 and Channel 4 there is somebody explaining what’s going off on the program and I don’t know how to get rid of the voice can you help thank you
My mistake I have a Sony Bravia TV on channels ITV3 and Channel 4 I have somebody narrating what is happening during the program and I can’t find out how to turn it off can anybody help thank you
This is called Audio Description, and you will likely find a button on your remote that says AD, which you will have pressed by accident.
Press it again, to toggle it off, and it will stop.
The button would be bottom left on a YouView remote, though I’m not sure where it would be on a Sony remote.
In the event you can’t find such a button, try the Sony menus for Accessibility, which will also likely have a place where you can turn it off.
