Streaming apps(disney plus/ amazon prime) not working
kokarav86
got a 55' smart sony android tv and since yesterday no streaming on apps, only bbc iplayer is working
any help?
Marino.Manolo
Genius
Try a simply reboot of Android TV, keep pressed Power/OFF on remote...
4 REPLIES 4
Marino.Manolo
Genius
kokarav86
many thanks
it did the trick
k
Roxby410
Does not work for me
HannahEd01
Community Team
Hey Roxby410, that's an old thread, could you clarify your issue, model number, the steps you've done so far?
