Zebanet
Tekstitys hävinnyt
Viikon vanha Sony Bravia KD 55XE8096 tekstitys katosi kaikilta kanavilta?
Zebanet
I did find the reason: after software update text language was changed into english in digitv text settings. I did change it back into finnish and problem solved..
jumpsuit
Hi @Zebanet and welcome to the UK forum :slight_smile:
Please try and use English here if you can.
In answer to your question about subtitles disappearing,
are you sure you haven't turned them off accidentally?
Zebanet
jumpsuit
Hi again @Zebanet
Thanks for letting us know :slight_smile:
