The SONY logo appears and then shows a black screen
mohamad61
Model : 50w800c
the sony logo appears for about 3 sec then the screen goes black, the power light stays green and using the remote to "change channels" makes the white light flash but the screen stays black.
Tags (1)
9 REPLIES 9
Peter_S.
Genius
Hi mohamad61,
Can you access the home screen or is it also black?
Have you seen a red blinking LED?
Please unplug the TV from mains for some minutes and see if it solves the issue.
Peter
mohamad61
hi peter
The lights are fixed and white
None of the keys work
It cannot be reset
Tags (1)
Gerardmci
Mine identical. Started as constantly trying to reboot, but getting to Sony screen then black, then Sony...
Now white led light on, screen black and nothing happening.
tried everything switched off and a reboot holding power and - sound buttons, but didn’t help.
mohamad61
you are right
Even pressing the volume and power keys still did not solve the problem
Joe_Dohn
Specialist
Have you tried manually applying the latest update using a USB stick?
profile.country.RO.title
Nikos1.
last night before going to bed I turned off normal sony tv KD-55X8509C
and in the morning when I turn it on my sony logo appears then it tries
to load the Android app after which it repeats the same procedure and then
the screen turns black and the LED stays on .
I don't understand what happened overnight, although a few hours ago it worked normally
can anyone help me if you have the same problem
thank you
mohamad61
I have the same problem
Tags (1)
mohamad61
Her latest version is a TV set
Joe_Dohn
Specialist
Hey Nikos1,
Have you tried clearing the cached data on the TV? (Home - Settings - Storage & Reset - Internal Shared Storage - Cached data)
- J.D.
