I'm trying to do the THX brightness test on my Sony XD93 and as you can see with the brightness on 10 out of 50. The picture stills looks badily washed out. All picture processing is off. I'm using the THX OPTIMISER on the T2 bluray disk. Any help appreciated.
Hi there
I am unsure on how it should look - but you could test using picture mode set to standard. But ultimately, you might need to start experimenting with additional processing in the advanced picture settings. Black levels, corrections etc.
