Todays software update
miscofi
I have KD65-XG9505 and updated to the latest update via USB today
Its switched me to the Freeview TV guide if I use the 'guide' button on the remote, instead of Youview.
The online instructions suggest there is a youview on/off selection in channel setup. But there isnt one.
I changed the settings so that the 'TV' button on the remote gives me Youview, but still stuck with Freeview via the Guide button.
What is the new location for disabling freeview please ?
Joe_Dohn
Specialist
I believe the YouView feature is now an app that you can access and is not disabled/enabled like the old version.
miscofi
Yes it seems so
Very confusing, because sometimes after activating YV with the TV button on
the remote, subsequent use of the Guide button sends you nicely to YV, but
randomly it reverts back to Freeview
Very odd design.
Can a Sony person possibly help with an overview of how this is now
supposed to work ?
