Tv / Alex / Amazon Prime app question
Prior20
Can we use alexa to control the prime app with the sony TV?
similar to the firestick & voice remote ?
EdwinaU
Moderator
Hi there,
It looks like this is not supported for Sony TV's as discussed here and here. However, it might be worth contacting Alexa support with info about your TV to see if there are any possibilities.
Cheers,
EdwinaU
