TV Echo on Headphone pairing
Kirmp043
I purchased a Sony KD-65A1 Nov 2017 and a Sony MDR 1000x Bluetooth headphones.
sadly I get delayed Echo from my TV speakers...very annoying but the sound in my headphones is OK.
On TV I have been to ..HOME/SETTINGS/SOUND/ and selected ‘Audio to both TV speakers & other devise’ to ON. ...as suggested.!
 I cannot cure problem.  Suggestion is use a HDMI connection..
Well, having spent £3999 on Sony TV and £330 on Sony BLUETOOTH headphones
....the WHOLE reason was to avoid having to use CABLES ???
  SONY....What do you suggest.
7 REPLIES 7
Kirmp043
Anybody else experienced this or similar.
....any solution ideas ?
Pascale_F
Moderator
Hi Kirmp043,
Welcome to the Community.
This sounds frustrating! I have passed your message onto to our team to look into and someone will get back to you here.
Best wishes,
Pascale_F
sj.taylor
Also get this
sj.taylor
@Pascale_F please see this post, for several other people with the same problem (my post)
https://community.sony.co.uk/t5/android-tv/echo-heard-on-tv-when-using-a2dp-bluetooth-headphones-and...
And also this
http://community.sony-europe.com/t5/android-tv/tv-echo-on-headphone-pairing/m-p/2402454#M23762
All the same issue
This must be fixed it's silly!
Drrron
I found a "temp fix" , go to the sound settings and adjust balance to the left or right speaker to Max. It helps keep down echo on TV. Does not affect headphone sound.
(I did it during playback with both TV speakers and Bluetooth headphones on, via Action Menu-Sound Adjustment-Advanced - Common - Balance) :slight_smile:
Bobby_Red
Same problem.
Sometimes after unpair BT, the TV speaker have this echo, too.
Can only geht read of this effect after cold start of the TV.
65A1
rooobb
The problem has been fixed on the latest fw, did you install it?
