Help needed pls. TV light in the bottom middle is flashing red and TV has burning smell.
Red light means failure, burning smell means potential fire hazard.
Unplug it at the mains immediately.
What TV model is it, who did you buy it from, and is it still under warranty?
The flashing red light is an indication of a major malfunction with the TV.
And if you can smell burning then that is confirms things.
Stop using the TV.
It might have been useful to include the TV model you are talking about,
what age is it and is it still under warranty.
If it is old and out of warranty it will probably be too expensive to repair, so buy a new one.
Unfortunately, a red blinking LED is not a good sign. There are several steps you can undertake to solve this problem. Perform each step before moving on to the next one.
BTW, if its blinking red and smells, its obvious its overheating, make sure all the vents are clear, not clogged up with dust or anything and make sure nothing behind tv is too close, it appears not to be the end following the steps mentioned but you will need to resolve whats causing it to overheat.
Hey @uveexxxx
I'd prefer that you contact Sony right away, as they have a specific department for such cases, so they can advise with the safest thing to do regardless of the warranty status and the service of the device.
Also, how many times does it blink red? Or is it a constant red light?
