TV Mac address
Lubbleys
TV Mac address
Hi
I'm trying to find my TV Mac address on my Sony KD43X8309C and can't find it anywhere.
Anyone know how to find this?
Thanks.
profile.country.GR.title
MiCal1967
Hi
It is:
Home - Help - TV information (View network status) - MAC address
Wired MAC is different than wireless.
4 REPLIES 4
Mick_J
Thanks.
On a KD43X8307 so perhaps the same, it can be found under Network Settings. In my case selectng the wired option as that is what I use displays the IP and MAC address.
Mick
MiCal1967
Hi
It is:
Mick_J
@MiCal1967 wrote:
Hi
It is:
That's right, selecting the active connection method provides the information, in my case wired. Using the help option rather than Network settings does save having to choose. :slight_smile:
Lubbleys
Hi
Thanks for the help everyone, I've found it now.
Thanks again.
Sent from my Samsung Galaxy smartphone.
