Since update to latest version 6.0.1 , after standby the sound ouput settings changes to TV speaker
Never had any issues in previous versions
Is this a known bug or is it a setting i need to change?
Solved! Go to Solution.
I had that even on lollipop. All controls were off on my denon and still, after turning off denon before the TV it switched to internal speakers. Which would be OK if only it would switch back to external after turning on AVR. At the end I switched back to optical and forgot about that ARC crap.
Check your bryvia sync settings, maybe remove the device (external speakers) and add them again. Good luck.
thanks, found a setting to prioritize sound system, never saw this before
seems to be working now
