When I switch on the TV (KD55A1) with the remote, the white indicator on light glows and the TV then switches itself off. If I try again, it usually switches on and stays on
Hi Jgn88n,
Have you tried to do a forced factory reset 5 times: http://bit.ly/2Xna889 ? I've heard that performing this more than once might solve the issue.
Cheers,
The_Black_Rose
I was about to reply today. I haven't had any problems since the recent software update. I think we can cancel this problem, but I will report back if it re-occurs
Hi RRG-Fafnir,
That sounds perfect ! Let us know if you faced any issues in the future after the update.
Cheers,
The_Black_Rose
Hi Jgn88n,
It's good to know that the retailer will cover the expenses. I believe the repair should be arranged from their side directly if your TV is out of the manufacturer warranty.
Cheers,
The_Black_Rose
Now just the small issue of Sony not playing ball with organising the repair! They’ve even asked me how much it would cost!
I cannot even to understand the logic displayed by Sony in this issue.
right.. im going to the sony centre in my local town, taking whichever TV I fancy and leaving mine there. Absolute farce of a company. No adequate response and it's been a long time now
