After a 7.0 Nougat update i get getting a message on the screen "fatal error" what does this mean? How can I resolve the problem?.
Solved! Go to Solution.
What I did was, clear the cache files then hold down the on/off button for 5 seconds, it cleared the message "fatal error" without doing a complete factory reset
Hi @Alundavies109 and welcome to the Community
Which TV do you have?
Is that all the message says?
Can you provide a photo?
Its probably best resetting your TV to see if that clears the message.
