USB 3.0 GIGABIT ADAPTER
D-Law81
As the ethernet port on sony TV only do upto 100 mbps if I was to put a USB 3.0 gigabit ETHERNET ADAPTER into sony x94j usb 3 port and used a tp link gigabit ethernet adapter would it work.????
76 REPLIES 76
Hughjarse
yes it is 10
Talat_tito
thank you for confirming this.  so for those interested,  android 10 is a must.
Soundizer
What speeds are you getting with Adapter?
Soundizer
That’s slower than my Sony Tv wifi speed. I get 300 to 350 typically.
whats your home internet speed provider
Hughjarse
Im getting 600 - 700  ( im on fibre 900)
Talat_tito
my subscription is fiber 240 Mbps and iam getting 230 mbps with low ping of 3 ms,  with wi-fi I get good speeds but ping goes high
Jitlaw_81
Had some buffering issues here and there with 4k, not all the time but even once or twice can be annoying. So I just bought the tplink adaptor usb 3.0 to Ethernet, as recommended by original poster d-law81 and am pleased to report it worked instantly no install etc. I have a Sony 83” master series 2021,  now getting 300-600mbps! buffering gone. Thank you (pics attached) hope it helps
augierjp
I also have tried the Cable Matters adapter that Vincent recommended but no joy on my  Sony KD-49XH8196. I've also tried a TP-Link USB 3.0 to Gigabit Ethernet Network Adapter. On the Cable Matters adapter, I did see the data lights flashing but on the TP-Link one there were no lights flashing. I did try both adapters on my Windows laptop to make sure the worked. Very frustrating as I have 500Mbs speed broadband and wanted to make full use of it. Hopefully someone out there may have a solution. I also could not see any settings that I could change to get things going.
Marino.Manolo
Genius
An Ethernet > USB adapter will only work on newer versions of Android TV and on some Platforms.
augierjp
Thanks for the reply and my tv is on Version 9
