USB HDD recording failing
yorkshiresoph
Hi there,
Since the recent update in the UK, I have been trying to record to a 32GB USB flash drive in the HDD REC slot. The timers are fine, the device is empty, but it fails every time and I can't seem to find any information from Sony's manuals as to why it doesn't work. The error message is:
Event could not be recorded. No registered HDD was connected.
I have registered, de-registered, re-registered, it just won't work, but the tv recognises it's there!
Someone please tell me where I'm going wrong! Thanks
Tags (4)
