VEVO app -not supported by my KD-49XD8005
profile.country.UA.title
xdvoleh
There is no result when i try to search VEVO app on Play Market TV app.
When i try to install VEVO app to my TV from Play Market web page on Chrome i get the message thet this apps does not support by your devaice. Why this happend to me? The same thing is with few other apps like Twitter for Android TV. All software and apps on TV are up to date.
Tags (2)
4 REPLIES 4
Marino.Manolo
Genius
Hi @xdvoleh,
I'm sorry but Andoid TV is "different" from Android, you can install from Google Play only applications optimized (from developers and for Android TV).
When these applications will take the code for Android TV they will availables on Google Play...
Manolo
xx4L0Mxx
There is a Vevo-HD music videos app on the TVs own Google playstore built for Android TV. It's the very first app listed for me under "entertainment"  apps.
Marino.Manolo
Genius
Ok, and this App don't boot after install?
Manolo
xx4L0Mxx
I just tried to install the Vevo app from the TVs own Google playstore. It installs fine, opens fine and the videos play with zero problems. I'm in the UK, don't know where op is from. Even if the content of the app is geoblocked, the app would still install and run without problems, just wouldn't play the videos.
