When using bravia sync, there is a lag when changing volume. If I use the native controller for my Pioneer VSX-1131 this does not occur. This is most prevailant when I hold the volume button down.
Can anyone test and confirm?
This did not happen with 5.0, so something seems to have happened with the update. Full factory reset has been performed.
Same problem here both Sony XD-93 TV and STR -DA2400ES volume also jumps up when pressing down.
Same problem with lag on Volume bar;
Bravia 2015 KDL-50W805C,
Version 6.0.1.,
Build SVPDTV15_EU-user 6.0.1 MMB29V.S31 3.865 release-keys
anything happends with this problem by years???
KD-85XH8096TV and YAMAHA HTR-2071 - changing volume by Sony RC do the big lag to change volume on HT (
(the same while try to change volume on TV over the Googles assisted apps (HOME)
Does the volume that the Sony display is in-sync with your Yamaha volume?
I have KD-85XH9096 and also have similar problems but the root to mine, as I believe, is that the Sony is not getting any volume feedback from my AVR - The Sony always turns on with volume 0 and if I hold the volume up then it gets really fats to 100 while the AVR adds not more then 10 to its volume.
not quite... - it's 1-1,5 digits not equal to thу Yamaha... - thats if i choose show volume in digits...
-in yamaha settings i can choose show it in digits or in -dB (i think thats diff bcs TV has the "0-100" digits scale but Yamaha only "0-97" /
.... i think that i have any feedback beetwin devices... ( its connected by hdmi with ARC and in settings i turn-on the "ARC" and "hdmi conttrol" (and in settings i had choose what kind volume is be while turning on TV - "last" or "mute" or "any from 0 to 97"
when ido volume change its do LAG... - as if it try to send info to Yamaha not over "speedoflight" hdmi but over 2400 modem connection... )
- and i cant normal control volume not only from SonyTV RC - any volume control the same... from smartfone contrrolled chromecast or from Google HOME ... - you do change the volume from 50 to 20 - it show on TV changing from 50 to 20 and over moment it back to 50 and again but only to 49... - you hhave to many times do "20" on remote controlled ***** and whait how it laged on TV to "20" back to "49" and again to 48 or 47.... - have to do "10" like thats all repeats for make volume more silent (
i can say to google assistфте "change volume to twenty" and can see how it changed to "20" but over moment back to the position where was (and do "+" or "-" only 1 - 2 digits to realy change it ((
Hi GreyTalon, so just to make sure I get it right, you have two issues, that the volume level doesn't match between the TV and the Yamaha when you change it, there's a difference of 1 or 1.5. The other issue is when you change the volume with the TV remote (or anything else from the TV) it reverts back to the old number? If it's not please clarify more. Also, try to unplug the TV from the mains, disconnect all the external devices, leave it for few minutes, then plug it back in and try again.
There's a new software version that has been released recently too, make sure that you have it on your TV using the instructions in the following link: https://www.sony.co.uk/electronics/support/lcd-tvs-android-xh80xx_x80xxh_x81xh-series/kd-85xh8096/do...
Hi HannahEd, almost clarify ) -
prblm#1: - exactly!
i think that lags goes from diff. betw yamaha' volume scale (it is from "0" to "97" and has step by "0,5") and SONY' scale (its from "0" to "100" and step is "1") .... - and it looks like SONY is spending a lot of time for trying to equal .... - slow response is happends ... and i realy do the most hardely pressing on volume key on RC for changing volume (thats sure is psyeffect :))....
prblm#2: almost...
when i change volume let's say in google home chromecast TV control *****:.... - we can smooth change volume by smooth sliding finger on circle... - or just put finger on any point of volumecircle to SET volume - and volume should changed quickly to that point ) ....
or eg if i say to Assistent: "okigoo... set tv volume to 30" (while it current 40)... - it do norm react and volume will changed to 30 but immediately chnge again but not to back... - to 39... - mean it can't change volume to "SETed".... it only change to "ONE STEP".....
- and i have to do by finger is not one slide but about ten slidings repeats to make it quieter... - and on each repeats - volume on TV is show next:
to the 30 and back to 38
and again 30 and back but to 37
and again is 30 and back to 37... again... (bcs on YAMAHA its set to "37,5" after "38"
and again 30 and back to 35 ...
ps: and of couse i have latest firmware on TV and of couse i tried to many diff. ways with diff. settings on each devices ... and connections .... and i tried put sound from TV over SPDIF (same behavior as a result)... - and my hdmi cables is good - beacose i have good stable "4k60p" picture on TV from my HTPC connected to NVIDIA 1060....
(and last my observation: when we disable ARC in yamaha setup - it all starts working fine!!! ...
eeeeh... - more precisely, it looks worked fine - because with "ARC turned off" - we have no sound ....
- but "LAG" is gone!
- and we can SET exact volume on remote - and it do "30" from "40" by ONE STEP.... - and it all we can see! - but not heard
(maybe it to hard understand how i try to explain that....
sorry ... - but i can make a short video to youtube if thats help ?! )
Hey @GreyTalon,
Have you tried clearing the cached data (under Device Preferences - Storage - Internal Shared Storage - Cached data) then restart the TV by holding power?
- JD
