- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
January 2020
January 2020
Volume wont get under 6
I have a sony android an KD49XG9005 for a week now and yesterday the tv refused its volume to get under 6. I tried with the remote, the buttons on the side, the app. I connected headphones but also their volume couldnt get below 6. I restarted the tv but nothing happened. My last hope was a reset and that solved the problem. I didnt installed any apps and didnt didnt do anything unusual before that happened. Does anyone know why it happened? Cuz i can return it to the store until next week to get another one. Should I?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2020
January 2020
If it is working now and the TV is fine for you, I wouldn't. It could have been a software glitch solved by the reset. You are covered by warranty in any case should anything happen afterward
