Wenn ich an meinem KD-55XD8599 einen Sender aufnehme (nicht HD+), dann kann ich keinen HD+ Sender ansehen. Der TV hat einen Doppel Sat-Tuner. Ist das so normal?
Hi @durik8 and Wilkommen to the User Community
Please try and post in English (if you can) when using the uk forum.
For English speakers - courtesy of Google translate:
"When I take a KD-55XD8599 a station (not HD +), then I can not watch an HD + station. The TV has a double satellite tuner. Is this so normal?"
Hi
You must connect a second Cable from Antenna Dish to SUB input behind your TV.
Sie müssen ein zweites Kabel von Antenna Dish an SUB-Eingang hinter Ihrem Fernseher anschließen.
That won't help. It is not possible to watch an FTA channel and at the same time record a scrambled (HD+) channel. The CI unnecessarily gets assigned to the FTA channel or probably is even hardwired to the first tuner. So a scrambled channel can't make use of the CI anymore.
Only FTA works this way ?
