What are these spots behind the A9G OLED Glass???
tmarsbars
Does anyone know what this is?
My TV is fairly new and upon close inspection I noticed that there are striations and artifacts behind the glass. They are physical and can only be seen when shining a very bright light on the screen or at certain angles.
Any help would be greatly appreciated.
Sean_Mc
Moderator
Hi there,
If you believe there to be an issue with your TV, then I would recommend to contact the support team here and they'll be able to advise you further.
Best wishes,
Sean
