Which Sony android Tv to buy??
aryankanse6
I have two options between the X7000f and the X8000f. The only difference between the two for me is that the X8000f has triluminous display while the X7000f does not Also as per Sony site both the TV's can be controlled by Google home and I wanted to know what it192.168.1.254means as I have a Google home at home.10.0.0.0.1
Tags (1)
rooobb
The model names you enlisted are the US ones in europe you find xf70 and xf80 but regardless the main difference between the two is the smart tv platform the latter being an android tv. It depends on you how much value the smart tv features since the xf80 is also a little more expensive due to this
LightFoot
Specialist
Hi @aryankanse6   Just to emphasise what @rooobb has already told you. The XF70 (X70F) is not an Android TV but a cheaper Linux TV with no play store.
