piter1984
X80C HDR update
I've seen that the 2016 uhd models xd75 xd70 and sd80 get  hdr firmware update.Will x80c get hdr update??As I know its almost the same as xd70.
13 REPLIES 13
Marino.Manolo
Genius
55" - A-MVA3, 49" - IPS, 8bit.
Manolo
piter1984
Thank You
piter1984
Can someone tell me how HDR looks on XD70 (without Triluminos display and WCG) Is it much much worse then  XD8505 for example
Hi there
Unless someone has both TVs to compare - it is unlikely you will get an answer and can be subjective to someone elese opinion.  I recommend you visit a retailer like a Sony Store or John Lewis/Curry's etc and compare them yourself.
