X850c small dark spot behind screen
Dvdmikeis007
Hi all, this just appeared in the last hour, a small dark dot that is under the screen and is very visible in most viewing.
Any ideas? I have had many issues with the panel since with got it, so i finally have to call Sony and be without a TV for ages??
Hi there
Are you able to take a couple of photos and post them here?  Also please reply back with the full model of the TV.
Its hard to know what it could be - As its only just happened, id rule out an insect.  Dead pixels?
