x85c Television - Webcam? Not listed in spec
jonny_guitar
Hi there.  I've ordered the x85c.  Please can you tell me if it has an integrated webcam?
Also will apps like Spotify and Skype be pre-installed?
Jonny
tennysonman
It looks like this model does not come with the camera integrated.
jonny_guitar
What are you sources?  Like I said it's not in the spec, though I read it does have face detection?
rooobb
I don't know the UK related site address but if you understand a littel italian you can have a view at the detailed spec here infoprodotti.sony.it/contents/instance1/files/document/2887KDX8505C.pdf
Face detection is per image processing not for looking at you :slight_smile:
