x900h restarted itself
yangma
it restarted itself making a weired noise for like 5 secs. happened twice. has this happened to anyone with tv? was wondering what causes this and what can be done to stop it
thanks
48 REPLIES 48
cliveo32
Hi mate yeah ive tried alot you could try turning auto update off i only
got hdmi 1 or 4 not 3 seems to make it worse for me when plug in 3 ...1 is
on enhanced and 1 but not 3 or 2 maybe try turn earc off worked for some
this has only happened after the latest update tv was fine till then hope
it works for you
vendee
I've been in contact with Sony UK support for a couple of weeks now. Last time they wanted to know what devices I had connected to each HDMI port. I've got a Marantz AV receiver connected to HDMI 3 and a Panny PVR to HDMI 1.
I just phoned them again a few minutes ago and they say that they have escalated my issue to their "technical team" and they will get back to me either today or tomorrow. Lets hope they sort it out. I had a wonderful TV before the v6.0384 firmware update a couple of weeks ago. The thing is, my TV reboots even with the connected devices switched off.
blues0ck
yes this problem is very  annoying especially after paying  a lot of  money for the 75"  version which suited my needs  (tv/gaming)  of which is now a paperweigh has i  tend to  watched  a lot of tv through headphones ,so when the loud crashing noise happens its quite deafing on top of spoiling the content im watching at the time ,i wondered what other bugs will get created  trying to cure this one ,if the 2.1 update wasnt ready  why release it
vendee
So I've just been on the phone to Sony support again (they were supposed to contact me) to find out what their technical team suggested. I was asked to change the following settings:-
Network+Internet> Home network setup> IP control> Set "Simple IP" to ON
Restart the TV then back into settings:-
Watching TV> External Inputs> Advanced settings> Set RS232C control to OFF.
This is on a Sony XH92 so the settings may differ on other units. Mine is rebooting itself 3 times a day so I should know if the problem is fixed within 24 hours so I'll post back in a couple of days with the outcome.
vendee
Its now 2 days since I carried out the settings change detailed above and I've had no more re-boots so it looks like that issue is solved. I still have a related issue about losing Dolby 5.1 passthrough to my AV receiver every 5 or 6 days and having to do a factory date reset to get it back but I think I'll start a new thread for that.
Traikus
I applied the settings listed above and am still experiencing the random restarts, sometimes 4 times a day.
Any update on a fix for this?
cliveo32
Not yet bud i have tried all the fixes nothing worked for me still
restarts 1 or 2 times a day i think sony no of the problems i think
they removed the firmware from the update site so hopefully a fix will be
soon ...
vendee
Sorry it didn't work for you. Did you restart the TV after carrying out the first step? The only other thing was that previously, Sony support told me to turn off Bravia Sync. That didn't work for me on its own but I left it off. Perhaps you could try that.
cliveo32
I'll give it a go bud cheers
Traikus
I'm still experiencing the restarts multiple times a day and have tried all the fixes in this thread. Anyone else still experiencing this?
