Xg 8096 update via usb
Dannya449
I have downloaded the firewire update onto a USB, I have plugged it into my TV and it recognises the update file is there but then tells me "TV cannot update via this usb stick"  any suggestions?
Marino.Manolo
Genius
10 REPLIES 10
Marino.Manolo
Genius
Try first to reboot Android TV by keeping pressed Power OFF on remote, and retry...
Dannya449
I have tried this already
Marino.Manolo
Genius
Try to unzip the file with WinRAR or, restore the TV to factory settings (after an update it is still suggested by Sony).
Dannya449
No still getting the same message
Marino.Manolo
Genius
Dannya449
This link seems to have done the trick. Thanks for your help bud.
Marino.Manolo
Genius
Dannya449
It seems to be stuck in a loop. Getting to about 20% then restarting the TV and going back to the start. Is that normal?
Marino.Manolo
Genius
No it is not normal, wait and if nothing change unplug from the socket for a few minutes...
