XH90 ITV hub (and others) app not showing everything
MrQwerty111
How come the ITV app, and other catch-up apps in the Sony select app area don’t show all programmes compared to the app built in to iPhone/tablets etc?
Why are the catch-up apps within the “Sony select” app anyway? Are they updated?
I can’t find the dedicated ITV app for example on the App Store on the TV so have to use the Sony select one, and it’s not showing all programmes.
Joe_Dohn
Specialist
The ITV app and other catchup apps are part of the YouView feature of the TV (might be called "Live TV & Catchup" in the newest software versions).
Can you give us more info about the "not showing all programs" part, what's missing exactly?
- JD
MrQwerty111
I have the latest update as of today on the TV.
I don’t have an tv aerial connected to the TV, i I just use the internet for the services on the TV as I have BT TV connected.
I can’t remember the specific TV program, it was wife who was watching but it wasn’t on the catch-up via Somy select I have to go on the BT TV and they have catch-up and was on there
Joe_Dohn
Specialist
The only program/channel I remember seeing an issue with was something on ITV, and using an aerial was the fix for it, so maybe give that a shot?
Hope this helps!
- JD
