XR-55A90J
nisudji
XR-55A90J
Hello, all.
My TV will speak the results of whatever I’m searching for, despite Talkback and Screenreader being turned off. I don’t think it’s Google Assistant causing the issue, either.
Can anyone help, please?
HannahEd01
Community Team
Hi nisudji, I don't believe that there's a setting on the TV for that, I'd contact Google for further assistance on this one.
9 REPLIES 9
LightFoot
Specialist
Hi @nisudji   Have you tried a soft reboot? Hold down the remote power button until you see Restart on the screen.
Lord_viridis
Do you mean the "showing results for ........."
It says after searching on play store ?
I can't find a way to turn it off either on my x95k.
nisudji
Yup, that’s exactly it.
nisudji
Thanks for the response..
Yes, I’ve tried all of that.
HannahEd01
Community Team
Hey nisudji, if it's saying "showing the results for" that's normal, it functions pretty much like the usual Google Assistant, if this is not what's happening, please elaborate more.
Also, check the software version and post it here. Press Help on the remote control, you should find it on the upper part of the screen.
nisudji
Hi, Hannah.
Yes, that’s what’s happening, but I’d like it to stop.
HannahEd01
Community Team
nisudji
Hi, Hannah.
Okie dokie,
Thanks for your help.
HannahEd01
Community Team
Hey nisudji,
It was my pleasure! Let me know what they say. :slight_smile:
