My Sony XR-65A75K OLED TV refuses to start when powered only red blink 5 times and repeats the blinking after a pause.
I have tried the unplugging and plugging the power plug while pressing the start button on the TV. This has worked twice with the TV working for a few days and relapsing to 5 blinking red lights with the whole TV not powering up.
Kindly help with some insights to this problem.
Thank you.
Red blinking LED is a sign something major is failing on your TV.
Is your TV still under warranty, if so contact whoever you bought it from and arrange
to have someone come out and check it over.
Have a read of this if,
If the TV is out of warranty then you may find a repair is too costly to justify and a new TV is the only option.
Thank you will give this a try
