youtube not loading on KDL-43WD756
profile.country.IE.title
nosoundjim
Hi Sony,
As the title suggests....
I've switched off power at the wall and restarted the TV but no difference.  The youtube logo comes up and just hangs there.
Any ideas what I can do?
Regards, Jim.
sound10
Hi, I have the 32WD756 and was having the same problem. Having spoken to Sony UK Support earlier today, YouTube is now working. Here is a link to my thread which gives the solution :- https://community.sony.co.uk/t5/other-tvs/sony-32wd756-youtube-app-suddenly-stopped-working/m-p/2510...
Hope this helps :slight_smile:
sound10
nosoundjim
Brill, that worked perfectly, thank you.
