YouView
Bjdr1975
YouView
Re: Any way to completely disable Youview?
I used to be able to disable Youview, as my wife somehow keeps enabling it when I'm not around and eventually the TV, a KD55 Af 9 packs up altogether. Since the last update and following the correct menus there is now no prompt for Youview disable once Channel Set up is selected. C.an anyone help, Cheers
10 REPLIES 10
Bjdr1975
I need the aerial to be connected to my recorder HDD, this then connects to the TV. The recorder has all the smart facilities that the TV has and these are what I'm using to watch the i players.
